• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • i-drop Enhancer Extension Developer
    New Member
    idrop doesn´t work
    48 Views, 3 Replies
    07-31-2003 05:05 AM
    Hallo i´ve downloaded the new idropindicatorsetup from autodeskpage and istalled.
    i´ve tested with the chair on the same site.
    if i put the mouse over the chair i see the indicator
    if i press the left mousebutton i see a circle with a line
    in. Whats wrong?
    Windows XP Prof SP1 IE6.0.2800.1106. AIS7.
    Regards
    Bernd
    Please use plain text.
    *mark webb, autodesk
    Re: idrop doesn´t work
    12-14-2003 06:52 AM in reply to: bernd
    All that is saying is that you cannot drop the
    i-drop content onto the web page.
    If you drag the cursor over AutoCAD, it should turn
    into the i-drop indicator when over the drawing
    Post back if this is not the case
    Mark
    New Member
    Re:
    When I downloaded i-drop it worked on the chair in the download page for this .exe file....but when I tried to download style from Point-A I could not get the i-drop icon to appear. Any suggestions on what I am doing wrong? Do I need to be in the subscription program to download? I am also working with ADT 3.3 could this make a difference? Thank you. Penny
    New Member
    Re:
    Hallo Mark,
    it works. I thought it´s the same as in Inventor with
    the library.
    Bernd
