• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    i-drop Enhancer Extension Developer
    Member
    MatthiasFostel
    iDrop on Windows 7 64-bit
    1359 Views, 1 Replies
    07-20-2011 02:28 PM
    We have an intranet using iDrop that doesn't seem to work on Windows 7 64-bit.
    I notice the primary download webpage for iDrop lists Windows versions only up to Vista.
    Has anyone been able to get it working on Windows 7 or perhaps there's another option?
    Thank you in advance.
    Please use plain text.
    New Member
    as6221
    Re: iDrop on Windows 7 64-bit
    07-23-2011 02:29 PM in reply to: MatthiasFostel
    Hi Matthias,
    iDrop does work on Windows 7 x64, however I've found the image behind the control doesn't always load (seems to be computer specific), but the rest of the control's functionality still works.
    Take a look at this article if you haven't already: http://usa.autodesk.com/getdoc/id=TS1071268
    In summary, if you are using 64bit Internet Explorer then you need the 64bit indicator executable installed and the website needs to detect using JavaScript that your browser is 64bit and give it the 64bit ActiveX ClassID in the embed/object tag in the page's HTML.
    If the website is only giving you the 32bit ActiveX ClassID then you'll have to use 32bit IE instead, in which case you need the 32bit indicator executable installed.
    Hope that is of help
    Alex
    Dell Precision T3400, Intel Dual Core 2.66GHz, 4GB RAM, Nvidia FX570 graphics.
    Windows 7 Professional x64, .NET v4.0
    AutoCAD Civil 3D 2011 x64, AutoCAD MEP 2011 x64, AutoTrack 9.00.
