• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    i-drop Enhancer Extension Developer
    Active Contributor
    Re: iDrop not inserting parts from website.
    01-17-2007 01:43 AM in reply to: ClementClark5983
    It is an Inventor problem, as far as I know.
    The AUTODESK test iDrop site is not working with Inventor.
    Since Autodesk make the product, I presume that their website (both the HTML and XML) are correct.
    Thanks anyway.
    Please use plain text.
    Active Contributor
    01-17-2007 01:44 AM in reply to: ClementClark5983
    I do not have an iDrop website that I have created.
    I am having problems inserting ANY iDrop into Inventor.
    Active Contributor
    02-09-2007 01:37 AM in reply to: ClementClark5983
    Some person would be so amiable to say if i-Drop works with parts and assemblies created with Inventor 11?
    Active Contributor
    02-09-2007 01:42 AM in reply to: ClementClark5983
    Yes,
    PARTS only.
    You can crate parts in inventor 11, and add them to a website (using iDrop technology). You can then drag these parts from the website to an ASSEMBLY file.
    If it's all working for you, unlike me :smileyhappy:
    Distinguished Contributor
    02-09-2007 03:52 AM in reply to: ClementClark5983
    You do not create or assemble in I-drop.
    You insert the part or assembly in i-drop from the website.
    -Sem
    Active Contributor
    02-09-2007 04:00 AM in reply to: ClementClark5983
    That's what I said - you create parts in Inventor, not in "i-drop".
    You insert parts (created in Inventor 11 and added to a website) from the website into an Inventor 11 assembly file, using iDrop.
    Do you have any information on my query above -- you haven't replied.
    02-09-2007 10:23 AM in reply to: ClementClark5983
    It is a little bit hard for me what you want. First you post about AutoDESK website which I thought you have i-drop problem and was trying to help you.
    Then I found out that you are try to use I-drop.
    So I do not know what you problem on i-drop?
    Are you developiing website to use i-drop? or using someone website to insert drawing by using i-drop?
    Let me know and I will try my best
    -Sem
