• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    i-drop Enhancer Extension Developer
    Valued Contributor
    Uninstalling and reinstalling I-drop
    2203 Views, 10 Replies
    02-06-2009 09:11 AM
    I have a computer in the office that the i-drop function is not working on.
    I have found the install program on the autodesk website but when i try and install it it tells me i need to unistall the current version first.
    How do I uninstall the i-drop program?
    There doesn't seem to be anything in the "Add/Remove Programs" part of windows and I can't seem to find it anywhere else.
    Mike
    Please use plain text.
    Valued Contributor
    Re: Uninstalling and reinstalling I-drop
    02-12-2009 07:38 AM in reply to: mhamson
    Anyone?
    Mike
    Distinguished Contributor
    02-13-2009 07:45 AM in reply to: mhamson
    Well, I can see it under "Add or Remove Programs" on my computer???
    Valued Contributor
    02-13-2009 08:11 AM in reply to: mhamson
    I've check three computers in the office and none of them list "I-drop" or "Autodesk I-drop" or anything close to it.
    Can if be removed another way...or overwritten some how?
    The only way i can think of is to re-install windows which is too much time and effort for a tool in autocad.
    Mike
    02-13-2009 08:18 AM in reply to: mhamson
    Here's what I see.
    Valued Contributor
    02-13-2009 08:55 AM in reply to: mhamson
    For whatever reason...it is not listed on any of our computers.
    I don't get it.
    Mike
    New Member
    06-24-2009 07:23 PM in reply to: mhamson
    i have the same problem, nothing in start menu and add/remove programs(replace by the equivalent name in vista).
    i am on Vista SP2, Internet Explorer 8. No other Autodesk installed.
    I installed it as a way to uninstall it as security software said that it was insecure and i have no need for it(go figure why it was there to begin with).
    well... in my case, it refer to the freely available i drop tool on autodesk website...
    Active Member
    12-17-2009 09:45 AM in reply to: mhamson
    I am having the same issue. I installed I Drop however it does not seem to be working properly. The I drop cursor shows but it will not drop the selected in a CAD or Revit file. I have to uninstall and reinstall the I Drop program however when I go to add/remove programs it is not on the list. Has anyone come up with a solution yet?
    New Member
    04-02-2010 01:18 PM in reply to: mhamson
    I know this is an older post but I found that if I use the InPrivate Browsing in IE8, the iDrop functions as it should.
    New Member
    AdamFotta123
    06-07-2011 07:55 AM in reply to: mhamson
    I have the same problem, saysI-Drop is installed but nothing shows up on add/remove programs.
