• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    i-drop Enhancer Extension Developer
    Active Contributor
    'There was an error getting remote file http://...'
    134 Views, 19 Replies
    02-06-2006 02:33 AM
    I'm in the middle of producing a AutoCAD drafting website with areas of idrop blocks, when dragging the block into a drawing I receive a AutoCAD error message 'There was an error getting remote file http://...'
    Could you give me some direction, is this a programming error or should I ask my web host to allow access to these files.
    Please use plain text.
    Distinguished Contributor
    Re: 'There was an error getting remote file http://...'
    02-06-2006 06:25 AM in reply to: BigDaftie
    Check the drawing name that you have on XML file and the drawing file. Or the path that you put on XML file might not be the same where the drawing file is.
    If you need further help, attach your XML file and I will try to help
    Sem
    Active Contributor
    02-07-2006 12:34 AM in reply to: BigDaftie
    Thanks Sem that would be great ... im sure its just a simple thing that I'm over looking!
    Active Contributor
    02-07-2006 12:49 AM in reply to: BigDaftie
    Active Contributor
    02-07-2006 01:14 AM in reply to: BigDaftie
    Third time lucky!!
    I've attached the XML file as a text this time.
    02-07-2006 09:46 PM in reply to: BigDaftie
    Here is your xml file and I would like to tell you what it mean and look what you did .
    You put your PEO001.dwg in this path " People/PEO001"
    But it would be good to put like "./People/PEO001" where dot repesent the current folder.
    Otherwise, it will be immpossible for the server to get your local path.
    If it does not solve your problem, attach the xml, the drawing and the pitmap image and then I will fix your problem and respond back to you
    You can visit my website http://www.students.yorku.ca/~yu859sem
    sem
    Active Contributor
    02-08-2006 01:30 AM in reply to: BigDaftie
    Thanks again.
    I have got rid of the error message, great help.
    Now when I drag the block in I just get the web address of the block and not insert the drawing block.
    Any other advice?
    02-08-2006 11:07 AM in reply to: BigDaftie
    I fix the problem.
    you do not have to use
    "http:\\idrop.autodesk.com\idrop-schema.xdr"
    I change your file.
    If it is not working let me know
    Sem
    Active Contributor
    02-09-2006 02:42 AM in reply to: BigDaftie
    Sem,
    Cant understand whats wrong!
    Is i-drop compatible with Autocad and architectural desktop or is it a different method?
    I attached more into
    02-09-2006 11:29 AM in reply to: BigDaftie
    I went to your website.
    Go to my website and e-mail me and I will e-mail you my number and then call me.
    I will help you
    Sem
