• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    i-drop Enhancer Extension Developer
    Active Member
    Temporary Folder Settings
    152 Views, 2 Replies
    05-10-2006 04:57 PM
    When I try to drag and drop an idrop drawing target from IE 6 (win xp) to Autocad 2002 i get the following error
    C:\Documents and Settings\Phill\Local Settings\Temporary Internet
    Files\Content.IE5\1O3IJN5Z\MB200A(B)[1].dwg is not a valid drawing
    It appears that the "Content.IE5" sub directory does not exist and i cannot manually create it. However, the drawing file is temporarily dropped to C:\Documents and Settings\Phill\Local Settings\Temporary Internet Files\ before it is inserted into the drawing
    is there any way change the temporary drawing location so that Autocad looks in the right directory
    Please use plain text.
    Active Member
    Re: Temporary Folder Settings
    07-21-2008 10:14 PM in reply to: poflynn
    Any one has answer for this. am also facing same problem . when am trying to drag from localhost folder
    kindly help
    shyam
    Distinguished Contributor
    08-26-2008 09:10 AM in reply to: poflynn
    Same here. Still no ideas on how to fix this?
    -Jeff
