• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • i-drop Enhancer Extension Developer
    *real JD, The
    I drop automation
    94 Views, 9 Replies
    07-24-2003 12:08 AM
    Are there any routines or scripts or utilities to simplify the creation of
    i-drop pages? I have a couple hundred blocks I'd like to put onto web pages
    and implement the idrop technology. I'm new to this, so any information
    would help. TIA
    Please use plain text.
    *mark webb, autodesk
    Re: I drop automation
    07-24-2003 12:29 AM in reply to: *real JD, The
    The Publish To Web feature in AutoCAD is worth a look see.
    regards
    Mark
    *real JD, The
    Re:
    Mark,
    Thanks for the reply. I'm using AutoCAD 2000i. I tried the publish to web
    feature wich creates a page with Jpeg or Dwfs. The page looks good, but how
    can I implement I-drop with it? I didn't see any option for this...
    "mark webb, autodesk" wrote in message
    news:f17a858.0@WebX.maYIadrTaRb...
    > regards
    > Mark
    Re:
    07-24-2003 03:04 AM in reply to: *real JD, The
    JD
    The Publish to Web feature introduced the ability to create i-drop in
    AutoCAD 2002 I believe. This functionality is also in the 2004 release.
    I am not aware of a tool that will do the same thing for a 2000i product.
    good luck
    Mark
    *jeroenberkers
    07-24-2003 04:18 AM in reply to: *real JD, The
    I am writing a Lisp to do for me what you want. It creates an i-drop-page
    from the current drawing, with an image (JPG) to display on the page. It
    isn't finished yet, but will be soon.
    Jeroen Berkers (NL)
    A2k - W98SE
    "The real JD" wrote in message
    news:CE79015CD4999D557B332B14230D7944@in.WebX.maYIadrTaRb...
    pages
    > would help. TIA
    *real JD, The
    Re:
    07-24-2003 04:32 AM in reply to: *real JD, The
    Very cool! Please post in the customer files and let this newsgroup know
    when it's done!
    "jeroenberkers" wrote in message
    news:4FFE635041E1961E126DF00B50163E05@in.WebX.maYIadrTaRb...
    > Jeroen Berkers (NL)
    > A2k - W98SE
    of
    > pages
    > > would help. TIA
    *jeroenberkers
    Re:
    07-24-2003 04:35 AM in reply to: *real JD, The
    I will, soon....
    Jeroen Berkers
    A2k - W98SE
    news:65AC64260BFE7EE4736CC507829F4761@in.WebX.maYIadrTaRb...
    > when it's done!
    i-drop-page
    > > Jeroen Berkers (NL)
    > > A2k - W98SE
    creation
    > of
    > > pages
    information
    > > > would help. TIA
    Active Contributor
    07-25-2003 07:53 AM in reply to: *real JD, The
    A year ago I used the 2000 product, and ScriptPro to generate jpgs of drawings.
    Then I process those with a photoshop utility I wrote in VB, which (among other things) resizes the jpgs to thubnail size, and writes a HTML web page to display those images using the idrop control, and generates the required XML code for the associated drawing.
    I don't yet mention on my web page anything about this part of the Photoshop utility (other than a screen image):
    http://www.well.com/~rhenley/actions.htm
    What the photoshop utility does not do is generate multiple HTML pages for each process run. Web pages with 300 images on them are a bit unwieldly, but initially usable for testing.
    *jeroenberkers
    07-28-2003 12:42 AM in reply to: *real JD, The
    I posted the application in the customer-files... i-drop-automation
    2000/2000i
    Jeroen Berkers
    A2k - W98SE
    pages
    > would help. TIA
    *Schmidt, John
    Re:
    07-28-2003 03:34 AM in reply to: *real JD, The
    rhenley - the multi-file processing utility
    you mention at your website looks like something my company could really use,
    but you have absolutely no information listed as to availability, etc. Is it
    possible to check this out somehow?
    John
    style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
    A
    href="http://www.well.com/~rhenley/actions.htm">http://www.well.com/~rhenley/actions.htm
