• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    i-drop Enhancer Extension Developer
    New Member
    I-Drop not working on intranet only
    849 Views, 1 Replies
    09-20-2011 02:49 AM
    Hi Folks, I've a strange problem with idrop content on our intranet site. I can use idrop from a mapped network source. I can use idrop from an externel web page like cadlibris.com. And also http://www.autodesk.com/us/developercenter/idrop/chair/id.htm works fine. But if I copy the source files from http://www.autodesk.com/us/developercenter/idrop/chair/id.htm to my local web servers(IIS6 or Tomcat 6) idrop will not insert the drawing into my ACAD 2010. It says that the dwg was created with an incompatible version of AutoCad. When I look at the file that AutoCad says is invalid, the content actually is a 404 html (file not found) response. I've played around with the path of the datafile src attribute, but to no avail... Any Ideas? Chris
    Please use plain text.
    New Member
    Re: I-Drop not working on intranet only
    09-21-2011 01:29 AM in reply to: christian.arndt
    Ok figured it out. IDrop system will only accept port 80 on the webserver. I had a different one...
    Is there a way of making IDrop work also with a different port?
    Regards, Chris
