i-drop Enhancer Extension Developer
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Float this Topic to the Top
- Bookmark
- Subscribe
- Printer Friendly Page
I-Drop and dynamic blocks
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
143 Views, 3 Replies
04-23-2006 08:37 AM
Hello!
I have a generally question. Is it only possible to import a dwg-file into AutoCAD via I-drop? Or can I also import a single block of a drawing?
Normally it's not so important, but the combination of dynamic blocks and I-drop is not so good. I always have to explode the "I-drop-block" first to get access to the dynamic block which I need (because I need to create a block in the drawing to add dynamic functionality).
Re: I-Drop and dynamic blocks
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
04-23-2006 10:13 AM in reply to:
mabe2k11
I-drop is working fine. If you want to insert a block from the internet to AutoCAD application.
Basically when you insert a block in AutoCAD you have to option either to insert exploded block or with out explode.
In i-drop it is with out explode.
Sem
Sem
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-06-2009 06:20 AM in reply to:
mabe2k11
can you send a command via script, lisp or some other method using I-Drop?
Options
- Mark as New
- Bookmark
- Subscribe
- Highlight
- Email to a Friend
07-08-2009 06:19 AM in reply to:
mabe2k11
if you know AutoCAD you can do it.
sem
sem
