• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    i-drop Enhancer Extension Developer
    I-Drop and dynamic blocks
    142 Views, 3 Replies
    04-23-2006 08:37 AM
    Hello!
    I have a generally question. Is it only possible to import a dwg-file into AutoCAD via I-drop? Or can I also import a single block of a drawing?
    Normally it's not so important, but the combination of dynamic blocks and I-drop is not so good. I always have to explode the "I-drop-block" first to get access to the dynamic block which I need (because I need to create a block in the drawing to add dynamic functionality).
    Please use plain text.
    Distinguished Contributor
    Re: I-Drop and dynamic blocks
    04-23-2006 10:13 AM in reply to: mabe2k11
    I-drop is working fine. If you want to insert a block from the internet to AutoCAD application.
    Basically when you insert a block in AutoCAD you have to option either to insert exploded block or with out explode.
    In i-drop it is with out explode.
    Sem
    New Member
    07-06-2009 06:20 AM in reply to: mabe2k11
    can you send a command via script, lisp or some other method using I-Drop?
    07-08-2009 06:19 AM in reply to: mabe2k11
    if you know AutoCAD you can do it.
    sem
