Pie Chart of Operation Machining Time in Excel Setup-Sheet
Laurens-3DTechDraw
Mentor Mentor
Laurens-3DTechDraw
For @rsalasidis I made this Excel-2007 Setup-Sheet that shows a Pie Chart of the machining time of each operation.
(See his idea on this: http://forums.autodesk.com/t5/hsm-ideas/graphical-display-of-setup-sheet-time-calculations/idi-p/682... )
It's on an extra tab to keep it in your sight when you have more than 10 operations it would otherwise be hard to see on the operations tab.
Another graph could be possible too of course but I thought this would be fitting.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
rsalasidis
Tried it out, and it looked really good. The graphical representation is excellent, and it provides a lot of other info as well.
It would be nice if Autodesk would incorporate it in the menu system (maybe as a SetUp Sheet / Graphical, so that one does not need to change the post processor settings each time.
Laurens-3DTechDraw
Vote for this idea to make it possible to select a default set-up sheet.
http://forums.autodesk.com/t5/hsm-ideas/having-the-capability-to-select-a-default-setup-sheet/idi-p/...
Laurens Wijnschenk
3DTechDraw
René for Legend.
