Message 1 of 9
Fusion360 cam problems with .stl and .3dm files
I am fairly new to Fusion360, but am now able to use the cam function to create gcode for parts I create in Fusion360. My goal is to mill surfboard fins that are given to me in stl format. I can import these files to Fusion360 as a mesh, but then I discovered that I could not use the cam function on them. I tried the convert function, but received warnings about the large number of triangles, and it simply froze up. I was able to get the file in .3dm format (someone else converted with Rhino), uploaded that, but Fusion360 simply freezes whenever I try to do anything, such as scale it to get it ready for cam.
Does anyone know if it is possible to use the cam function on files like this? I found the interface to Fusion360 cam intuitive and easy to learn, and am really hoping I can find a way to make this work.
In case anyone is interested, here are links to the stl and 3dm files I was trying:
https://www.dropbox.com/s/7hmx5493jd4xdv3/finfoil4.stl?dl=0
https://www.dropbox.com/s/rzgiahfu5sfyxai/finfoilNURB.3dm?dl=0
I'm using Fusion360 on the Mac
Thanks very much, and I apologize if the answer to this is completely obvious to those less ignorant.
Ric
Ric
