HSM Post Processor Forum
Where to put .cps files for Fusion 360
17 REPLIES 17
Message 1 of 18
20123 Views, 17 Replies
Hello!
I've successfully customized my post-processor, but I'm wondering where the correct location is to place them for an OS X install of Fusion 360. I've previously been placing them in /Users/MyName/Library/Application Support/Autodesk/webdeploy/production/version hash/Libraries/Applications/CAM360/Data/Posts, but that's obviously problematic, because every time a version changes those get lost.
Sorry for the trivial question, but I can't seem to find the right place.
Thanks!
17 REPLIES 17
Message 2 of 18
tomae
in reply to:
See this thread: http://forums.autodesk.com/t5/computer-aided-machining-cam/tormach-pathpilot-post-processor/td-p/5816159
I have been using the cloud posts and have had no issue with it, but you can store it locally...
-Tom
Message 3 of 18
in reply to:
Okay, got it! For anybody in the future that finds this thread, the location is not /Users/username/Fusion 360 CAM/Posts. The correct location on OS X is /Users/username/Autodesk/Fusion 360 CAM/Posts (despite that both folders are created by the installer).
Message 4 of 18
AchimN
in reply to:
You can store your customized posts anywhere on your computer locally and select the right folder during post processing, see screenshot attached.
Achim.N
Principal Technology Consultant
Message 5 of 18
George-Roberts
in reply to:
Does it work like that on a Mac? I thought you could only use 'Default Posts' or 'Personal Posts'?
Message 6 of 18
fredsi
in reply to:
George,
On the mac you have three sources: Generic (buried deep in the folder structure of the install), Local or personal (usually modified ones) in the folder indicated by 542458, and Cloud posts - essentially copies of what you normally use stored on A360.
Since I don't really trust the install procedure on the Mac, I keep additional, separate copies of modified posts in another, less vulnerable location.
Fred
Message 7 of 18
Laurens-3DTechDraw
in reply to:
Fred Siedenburg wrote:
George,
Fred
Personally I would say put them in the Cloud post folder. Since it's a cloud product and having your posts locally voids the purpose of the cloud. But I have no experience in how well that works.
And what you say here Fred, having a back-up is always a good idea for personalized posts. I even do this for the post folder(Not the default program files folder) I use at work.
Laurens Wijnschenk
3DTechDraw
AutoDesk CAM user & Post editor.
René for Legend.
Message 8 of 18
George-Roberts
in reply to:
Thanks for the info 🙂 Useful to know! I don't spend as much time as I'd like on my mac, so haven't had much time to get used to the OSX / fusion workflow 😞
Message 9 of 18
jmvar44
in reply to:
Hi, I'd like to post to the cloud but can't seem to get the CAMpost folder to show up in A360 under Data.
I have followed this video specifically the steps at 0:22 : https://youtu.be/waMpsv7HIKw?t=22
And I look of for the folder as done at 2:58 : https://youtu.be/waMpsv7HIKw?t=178
I don't get the Folders that Curtis has visible under Data tab.
Any help is appreciated.
Message 10 of 18
HughesTooling
in reply to:
The dashboard's had an update, see this thread.http://forums.autodesk.com/t5/computer-aided-machining-cam/new-dashboard/td-p/5878156
Mark
Mark Hughes
Owner, Hughes Tooling
Message 11 of 18
jmvar44
in reply to:
Mark
Thank you, that was exactly my issue, all works now.
Message 12 of 18
maker9876
in reply to: AchimN
Hi I'm using Fusion360 OSX and don't find the window corresponding to your attached screenshot? Want to select a post processor file on my hard drive. Any ideas where to look?
Message 13 of 18
maker9876
in reply to: maker9876
ps have tried the cloud option as explained by @HughesTooling
Since his post the interface for A360 has radically evolved but my .cps is now in the appropriate place in the cloud. However 1hour later and despite restarts it's still not appeared in F360. ;(
Going to find a different workaround to mill my part.
Message 14 of 18
HughesTooling
I don't think it's changed too much from that post.
After enabling A360 Drive in your settings you will have this option to view files on A360 Drive.
In A360 Drive Fusion should have created these folders.
Clicking the posts folder should give you this.
Mark
Mark Hughes
Message 15 of 18
maker9876
in reply to: HughesTooling
Yes, that's the one!
Now the Post processor has finally synced to the Offline Software so all well and good.
What I couldn't find was the dialog to enable direct import from the Hard Drive to Fusion360 offline?
Could only find the options below... (OSX)
Message 16 of 18
offaxis
I am new to CNC but have a Weihong NK105G2 handset for my AccTek AKG6090 and followed the forum link below to get the .cps file.
http://forums.autodesk.com/t5/post-processors/post-processor-for-weihong-nk105-solved/td-p/6091825
How do I now access / add this custom .cps to the Fusion360 Post Process 'Post Configuration' drop down menu?
Regards Hugh
Message 17 of 18
matthew.nichols
in reply to:
@offaxis
I like having a local folder of my custom post processors. When you hit the post process button at the top you can path it to that local folder and it will always default to that after the first post process.
Matthew Nichols
Adoption Specialist - MFG
Message 18 of 18
offaxis
in reply to: matthew.nichols
OK got it sorted, thanks
