Hello, I would like to start using Fusion 360 for my CNC Plasma work instead of exporting a DXF file into Enroute to generate the CAM for my Sidekick 4x8 table. The default WinCNC file does not work at all and fails to even generate a TAP file with Plama not supported, see below:
Information: Configuration: Generic WinCNC
Information: Vendor: WinCNC
Information: Posting intermediate data to 'C:\Users\Trickle\OneDrive\Documents\DXF files\Porsche 911\Muffler flange plasma cut.tap'
Error: Failed to post process. See below for details.
Code page changed to '1252 (ANSI - Latin I)'
Start time: Tuesday, January 24, 2017 8:30:33 AM
Code page changed to '20127 (US-ASCII)'
Post processor engine: 4.2.1 41279
Configuration path: C:\Users\Trickle\AppData\Local\Autodesk\webdeploy\production\8a3277547d9773e7c7326703a2421ef122443b08\Applications\CAM360\Data\Posts\wincnc.cps
Include paths: C:\Users\Trickle\AppData\Local\Autodesk\webdeploy\production\8a3277547d9773e7c7326703a2421ef122443b08\Applications\CAM360\Data\Posts
Configuration modification date: Tuesday, November 08, 2016 8:37:19 PM
Output path: C:\Users\Trickle\OneDrive\Documents\DXF files\Porsche 911\Muffler flange plasma cut.tap
Checksum of intermediate NC data: f67859db9cfded7473afaf3cc1d383db
Checksum of configuration: f8f0b1850526630819bbefbc35c92176
Vendor url: http://www.wincnc.net
Legal: Copyright (C) 2012-2015 by Autodesk, Inc.
Generated by: Fusion 360 CAM 2.0.2676
Error: Waterjet, laser, and plasma cutting toolpath is not supported by the post configuration.
Error: Failed to invoke 'onOpen' in the post configuration.
Error:
Error: Failed to execute configuration.
Stop time: Tuesday, January 24, 2017 8:30:33 AM
Post processing failed.
