Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Some Entities are Degenerated
2 REPLIES 2
dcgall
348 Views, 2 Replies
I'm trying to convert a TSpline and I'm getting an error that "some entities are degenerated".
What does that mean?
thanks,
2 REPLIES 2
deyop
in reply to: dcgall
Are you getting any visual feedback on the screen when it fails?  There should be some red highlighting where the problem occurs.  It could mean that there are multiple vertex in the same position which are not merged together.  If you can provide the example I will try to give you a better explanation.  We have updated error messages in the latest release but this error may not have been addressed.
dcgall
in reply to: deyop
I discovered the red highlighted faces and corrected the problem. It would be helpful to have a little bit more info in error messages which could lead to a solution. Thanks for the response.
Sent from my iPhone
