I make a sketch and i use the fillet command a lot.
But if i draw more fillets, the drawing is slower and sloooower and sloowwwweeer.
At this time, make a fillet it's about a minute or more. If i set the fillet sketch with the handle arrow or type the numerical value the result is the same: extreme slow validation (and my CPU activity push to 100%).
And one more strange detail: it's happening about 90% when i use the sketch fillet tool. The 10% of fillets are quick as usual as any other commands. Maybe is it depends on constraints or concave/convex drawing? I don't know.
Every other finctions are fairly quick and responsible.
I use Intel i7 CPU with 16GB RAM and the newest OSX.
Thanks for posting about this problem.
Unfortunately we were not able to reproduce the problem here, is it possible to attach your model to the forum? You can save the file as an f3d file using the Export Archive tool in the application menu.
If you would rather not post the model here, we can arrange another way to transfer the file.
You also can email me if you like. cathy.wang (at) autodesk.com
Hi Cathy!
Mail sent.
My actual workaround: i don't use a fillet at the sketch, but on the solid body.
Thanks in advance!
Thanks for sending the mail. I will take a look at the problem.
It’s good to know you have a workaround for your model.
Thank for you to post the problem.
I will deliver it to develop to fix it.
Thanks for reporting this. I am interested to know if disabling sketch profile visibility may help performance. To do this right click on the sketch in the browser and select 'Hide Profile.'
