Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Sketch geometry is over constrained
6 REPLIES 6
511 Views, 6 Replies
When setting up construction lines get an over constrained error.  Some recommendations:
1.  Show me which constraints are causing the error.
2.  List possible solutions
6 REPLIES 6
SallyYang
Thanks for your feedback! We will consider your suggestions in future releases.
Hope to get more feedback from you again.
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
Helmi74
in reply to: SallyYang
This would be really helpful especially because the annoying bug that causes this error simply when ending a rectangle creation with enter instead of a mouse click is still there in the new version.
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
gutenbar
Is there any advance in this point?
It would be very nice to know which existent constraint is related to the action. It is a usability question.
g-andresen
in reply to: gutenbar
if you share an sample sketch and describe the problem area, something could be said about it.
günther
gutenbar
in reply to: g-andresen
Hello Günther,
That was an isolated problem. It is normal I face restrictions caused by
constraints without information about what constraint is involved.
Generally, I locate it/them easily, but last weak I had a sketch where I
could move the lines freely using the mouse, but the program did not let me
specify a position using dimensions, even the wanted dimension been among
the values positioned with manually. Very strange.
I think that until today I saw only once, on the alert screen, indications
about what constraints were locking the drawing.
Thanks for the attention
Gutenberg
TheCADWhisperer
@gutenbar wrote:
Hello Günther,
…but the program did not let me
Very strange.
Exactly the type of files that should be Attached here to get attention from the sketch solver team.
