Sketch dimension to projected lines.
1 REPLY 1
TheCADWhisperer
231 Views, 1 Reply
It seems that I can only select projected points for sketch dimensioning - not lines.
Is this the correct behavior?
1 REPLY 1
SallyYang
in reply to: TheCADWhisperer
Many thanks for posting the issue to us. The dimension between point and projected line should be supported. I suspect it wrongly projected to be a spline, so the dimension for "line" failed in this case. Could you share us the file to help us address the issue? You can either attached the file to the post or send it to sally.yang(at)autodesk.com .Thank you in advance!
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
