Show only
Search instead for
Normally when you make a selection "box" can also take the points that are on the other side of the model ... Fusion with 360 this does not happen, at least I can not do that!
I think I understand now. You can select any body, face, edge or vertex from the other side by turning off the Select Visible option in the Select Filters.
