now that SIM 360 is no longer supported, is there anyway of retrieving the CAD data from obsolete simulation files? I had a few sim files where I had itterations of a model with different setups all in one simulation file. Now I can't seem to be able to retrieve the geometry from that file.
Solved by innovatenate. Go to Solution.
Have you tried looking in the Simulations folder created in the project for Fusion Designs?
Yes - the only cad data I found in there was an old version. The Sim model have geometry that was several iterations newer.
I'm creating a support case for you. Look for an e-mail to follow shortly.
