Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Replace Face - clever solution needed.
5 REPLIES 5
TheCADWhisperer
376 Views, 5 Replies
In the attach file there are blue and red faces that I need to combine into single faces.
Anyone have a clever workaround in Fusion?
The problem is that if I try to add a Chamfer that goes beyond the red face - it fails at the intersection with the blue face. (see attached file)
5 REPLIES 5
SallyYang
in reply to: TheCADWhisperer
Please try my workaround to see if it meets your requirement:
1. Select blue face and delete it
2. Roll to the end of timeline
3. Delete the last sick Chamfer feature from timeline
4. Chamfer again on the edges you want.
The result on my side is:
Sally
Sally Yang
Software QA Engineer
Fusion 360 Quality Assurance Team
Autodesk, Inc.
TheCADWhisperer
in reply to: SallyYang
Can you attach your "solution" here?
Based on the image you attached - I don't think you understood my design intent.
I am trying to find a clever way of creating an ACME 29° thread form.
SallyYang
The file was attached, please check it.
Sally
Sally Yang
Autodesk, Inc.
SallyYang
You can also delete red face to make chamfer face extended to cylinder face.
Sally
Sally Yang
Autodesk, Inc.
donsmac
Here's an idea for making an ACME thread:
Combine a cylinder with a coil that has a square section. Bevel the edges of the coil using 14.5 degree angle.
On one edge I could not get the bevel to go the way I wanted ? so I duplicated the body and flipped it and overlapped it with the original so we see the bevel on both sides.
