Profile Facebook field : not accepted
4 REPLIES 4
albertuan
482 Views, 4 Replies
When I try to update my profile and insert my facebook url it does not accept.
https://facebook.com/formazione.strazzabosco
4 REPLIES 4
philip.s
in reply to: albertuan
Hi Alberto!
Can you confirm that you were adding it in the personal web page field under the Personal Profile tab? Any luck if you try switching browsers?
albertuan
in reply to: philip.s
Yes.
Page is http://fusion360.autodesk.com/my/profile/edit
Attached to this there the error screenshot.
philip.s
Got it!
Looks like the site is having a hard time with the "."s in the facebook URL. I'm looking into a permanent fix, but as a workaround, please remove the "." and use https://www.facebook.com/formazionestrazzabosco.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
philip.s
Wanted to follow up and confirm that this one has been resolved on our end!
