What is the problem? I was doing the tutorial (razor) exactly, but my body is not changing when clicking the matrial part.
I've tried new project and just basic ball wasn't changing either. I choose the bodies first and clicked matrials option, but after clicking it, the selected body turns into blue line which I think it should be whole blue body.
Hi, ykim613,
Thanks for posting the feedback.
Yes, currently after clicking the material, the highlight will become the blue line. and I agree with you, it's better that can show to be whole blue body. I will mail to Dev and PD to suggest to
the behavior. If have upate, will let you know.
Thanks again!
-Wendy
Thank you for reply. I've figured it out the problem. After clicking the object that I want to change, I had to drag the material into that object(not just clicking that material tab).
Great to know that you have resoved the issue. Yes, user need drag the materials into the object.
BTW, if you want to know more, please refer to the link which explains the material apply/edit workflows:
-Wendy
