Hi, I am working with someone that uses Solidworks and it turns out that it generates a folder with the several subparts of an assembly. In the import panel in fusion I can only select the assembly file and then I get an error log telling it could not find the subparts, which are actually in the same folder.
Is there any workaround or this feature is not yet implemented?
Are all of the SLDPRT, PRT, ASM, & SLDASM located in a single, flat directory with no sub-directories?
When using the "Import CAD Data from my local hard drive" command, is the "Import an assembly" radio box checked?
Can you share the Solidworks data with me? Feel free to e-mail to nathan (DOT) chandler (AT) autodesk (DOT) com.
Sorry, I am afraid that the problem is with the files themselves, not Fusion's mistake. Thank you anyway for your reply.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
