Opening my current work file again, I'm in the Model workspace with direct modeling, and I'm discovering that I cannot use the Press-Pull command without an immediate crash. This is a pretty simple file, and I'm just trying to press-Pull the sides of a rectangle, but even trying other objects the command crashes Fusion.
Suggestions?
Add another crash- I verified that Press-Pull works in other files, and worked on a cylindrical object in the problem file, but when I try to use it on either of the prismatic shapes in the file I get a crash. This last one was a long hang, I had to force quit, I did not get the report dialog.
Hi Kingson,
It's a strange one- a couple of the prismatic shapes in the file seem to cause crashing, but if I replicate them exactly as a new body and copy that into the component I have no problem. Seems as if something is corrupted.
Thanks for reporting this issue.
I am the developer of press/pull feature, recently i fixed a couple of crash issues on mac. Some are caused by me and some are caused by others.
Do you have a detail workflow to reproduce the crash so i can verify it.
Or can you see me your simple file to me?
Hi Sunneven,
Thanks for your reply. I think our friend Ron has the latest situation on Push Pull Crashes. My situation might had been corrected already. Since some time ago I had already found ways to get around those crashes. When I was designing very small objects like the solid graphical objects on Ring bands, I usually have to push pull very small items of say 0.10 or 0.05mm diameter up and down and usually those will generate crashes if I am using the mouse cursor to drag the arrow. I found a way to minimize it and I had been using that since then. I kind of touch the arrow and plug in the numbers instead. I think the crashes usually occur when push pulling very small round shape or disk shape objects. Lately I had been working on bigger size Pen Holder sets and the sides are bigger and the push pull seems to be fine. I think Ron's situation is similar to my situation before and he should be able to give you files that you can reproduce the events.
Sunneven,
The workflow was:
Open File
Switch to Model workspace
Select Push-Pull command
Select an edge of the prismatic shape
Attempt to move the edge with the manipulator= 100% crash of Fusion
I confirmed that I get this same crash with just the single box part when I saved a copy. I'm attaching one of these files. There were two parts in the larger file that caused this crash, both were simple box forms. If you need the complete file let me know where I can email it.
