parts from base feature hidden in timeline
4 REPLIES 4
cekuhnen
478 Views, 4 Replies
and another show stopper bug in Fusion:
a part from a base feature always is hidden when leaving edit going back to the timeline
this is another bug which makes currently Fusion nearly unusable because of this. I had this happen today in this file quite a lot copy paste hide show explode join sometimes helps. this one is resisting!
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
4 REPLIES 4
jeff_strater
in reply to: cekuhnen
It looks like it is Body75 that is missing/invisible in the attached file. Do you still have the source file that you inserted into this file? I'd like to try to see if I can reproduce/debug/fix it.
Jeff Strater (Fusion development)
Jeff Strater
Engineering Director
jeff_strater
in reply to: jeff_strater
Sorry, I mis-read this the first time. I think we have enough to investigate. Thanks,
Jeff
Jeff Strater
jeff_strater
Still looking for the underlying cause, but I think I found a workaround that will fix the design.  If you just edit that base body, then do some kind of dummy edit on this body (I did a press pull of this face by 2 mm, then back by -2mm):
then, after exiting Base Body mode, this body appears to be OK.
We will keep looking at the root problem.  Thanks for reporting it!
Jeff
Jeff Strater
jeff_strater
It turns out that the workaround is even simpler - just a Compute All seems to bring all the bodies back. Still trying to track down the cause, though. Let me know if the workaround works for you.
Jeff
Jeff Strater
