I have a part that is not showing in my browser and does not seem to be editable. I made a base feature drew a spline curve and extruded it then converted it to a T-splines object (the purple one) and boom there it is and all I can do is move it. Can't edit it. Notice all bodies are turned off/hidden and it's still there.
Any idea what it is and how I can edit it?
Thanks!
Damon360, thank you for using Fusion 360, the issue you mentioned is really a problem currently, we have put it into our issue tracking system and noticed develop team to take care of it.
And if you want to create some Tsline objects, please use Create Form command then continue your work.
Gavin
