Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Offset Sketch Projected Loop Anomaly
1 REPLY 1
TheCADWhisperer
218 Views, 1 Reply
Edit the last sketch and try offsetting the loop.
See the attached file.
I included draft and a 0.5mm clearance.
1 REPLY 1
Thanks your post!
I supposed we project the edge one by one. So we are not loop.
You can have a try to project the face on the bottom of "Heart". (Create a sketch, Invoke project and select the big face on bottom of the "Heart").
Or, you also can use "Project Silhouette" (Create a sketch, Invoke project silhouette and select the Solid body "Heart")
Cathy Wang
Software Engineer
Fusion 360 Team
Autodesk, Inc.
