I just noticed that from time to time I cannot move objects inside the object browser up or down the list.
The insert marker does not appear. With objects then it seems to work.
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
Can you attach the file with a screen shot showing what object you are trying to move and where you are trying to move it to?
Any
Here is a screencast:
https://drive.google.com/file/d/0Byzv_NlyKp_2c0pKdElfS2pRaVE/edit?usp=sharing
You will see only solid objects seem to move - mesh objects not at all.
Claas Kuhnen
Hi Claas,
I can see the issue on the model you sent earlier – you’ve found a legitimate problem here, many thanks for raising it! I’ll log this with the development team and we’ll get this looked at.
Much appreciated,
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
Hi Anthony,
Just to double-check - the issue we found on Claas's model is specific to mesh bodies. Is this where you were experiencing the problem as well? If not, let us know, just in case there's potentially something else to follow up here.
Thanks!
Jake
Jake Fowler
Fusion 360
Hi Jake,
My use case example would be...
A solid body inside a component that is then mirrored.
Create a mirror of the component so you have two instances inside the mirror subbody folder.
Try to move the two bodies down into the root bodies folder in the component, as the mirror sub folder seems like overhead in my general workflow, and I always delete them.
Quite often, though not the dominant experience, you can highlight and drag the bodies, but the move hints within the browser tree dont appear, and nothing happens on mouse drag release.
Thanks for these details! We'll look into this and make sure your scenario is also being covered by the development team's investigation.
If you see this occurring in any other circumstances, please do let us know; we'd like to get this properly resolved.
Much appreciated,
Jake
Jake Fowler
Fusion 360
