mirror / clone / offset complete sketch plane incl. sketches
1 REPLY 1
cekuhnen
284 Views, 1 Reply
is there a way to clone and offset a sketch including all the drawings inside the original sketchplane?
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
1 REPLY 1
innovatenate
in reply to: cekuhnen
You can copy and paste sketch entities from one active sketch into another active sketch with Timeline enabled. To do this,
1. edit the sketch that contains the sketch entities you would like to replicate
2. select the sketch entities (the sketch entities should be highlighted)
3. execute Copy Command (Command + C : Mac  or CTRL + C : Windows or Use right click menu option)
4. execute Stop Sketch command
5. create New Sketch on desired plane or geometry
6. execute Paste Command (Command + V : Mac  or CTRL + V : Windows or Use right click menu option)
If you disable the Timeline by selecting Do Not Capture Design History, you may copy and paste an entire sketch from the model browser, just like you would a body or a component.
I hope that helps. Let me know if you have any questions.
Nathan Chandler
Principal Specialist
