Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Mac OS X: Fusion doesn't wake up from sleep
3 REPLIES 3
Helmi74
338 Views, 3 Replies
this was already discussed in the thread about Mac instability but i wanted to bring this to more attention- think this should be solvable relatively easy.
Whenever the Mac goes in Standby and is there for a while Fusion360 seems to not wake up back from sleep. It doesn't matter if it's the dashboard only or a design is opened, too - you get a beachball as soon as you try to bring it to the front and that beachball doesn't go away again. Only a force quit solves the issue. A CER is not generated.
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
3 REPLIES 3
TrippyLighting
in reply to: Helmi74
I just came across this post and see that it has not received any reply. I find the same is true even with the most current update of F360 and with the most current version of Yosemite. When the Mac has gone to sleep and I wake it up, F360 is not waking up.
Peter Doering
innovatenate
Hopefully we should see some improvements around this with the upcoming release.  We have found some things that are similar and have gotten some fixes for them.  If we are correct, this issue will be resolved. Please keep monitoring this type of issue once we push the update.
Nathan Chandler
Principal Specialist
Sounds good! Thanks for the feedback.
Peter Doering
