this was already discussed in the thread about Mac instability but i wanted to bring this to more attention- think this should be solvable relatively easy.
Whenever the Mac goes in Standby and is there for a while Fusion360 seems to not wake up back from sleep. It doesn't matter if it's the dashboard only or a design is opened, too - you get a beachball as soon as you try to bring it to the front and that beachball doesn't go away again. Only a force quit solves the issue. A CER is not generated.
Hopefully we should see some improvements around this with the upcoming release. We have found some things that are similar and have gotten some fixes for them. If we are correct, this issue will be resolved. Please keep monitoring this type of issue once we push the update.
