Is there a way to measure volume (or mass if given density) of a body?
15 REPLIES 15
Message 1 of 16
AvihooI
8752 Views, 15 Replies
I would like to measure the volume of a body in order to figure out what its mass would be. Is that easily possible in Fusion 360?
15 REPLIES 15
Message 2 of 16
in reply to: AvihooI
Hi You can get those properties by right clicking on the root component at the browser and select properties: Two screen shots to show you here:
Message 3 of 16
AvihooI
Thank you,
I actually found out that feature two hours after asking the question and was giving myself a facepalm 🙂
It's good to have this as reference though cause I couldn't find it using the search option or on google!
Thanks again!
Message 4 of 16
Hi I deleted the last post because I would like to add a few more points. Yours is a great question! I used  "Mass" from Properties to estimate the approximate cost of materials to be used in the actual model. Most of our projects will be made by Plastic Injection Molding method and the approximate Mass is quite important. To get the X, Y, Z dimensions I would save an STL file of the model and use a 3rd party 3D reader to get the dimension information.  When 2D drawing is available for Mac Fusion users we should be able to get the dimensions within Fusion.
Message 5 of 16
jfanchin
Just wanted to check on if the volume/mass calculation is available for Mac yet?  Having some trouble locating ...
Thank you
Message 6 of 16
Phil.E
in reply to: jfanchin
Hi thanks for posting to the forum.
The properties for your parts are found by right clicking on the component node in the browser. Use "properties". It's the same for Mac or Windows.
Phil Eichmiller
Software Engineer
Quality Assurance
Message 7 of 16
jfanchin
in reply to: Phil.E
Thank you, I found that info on the Internet, but the root cause of the issue was that I was using an Apple mouse that didn't have a right click button. I assumed the Mac version was different and that commands might have been located differently, but once I guessed that it might be as simple of a hardware issue I was able to get it sorted out.
It might be a great helpful tip online though to make sure you have full functional mouse to access all features.
Thank you,
Joe
Sent from my iPhone
Message 8 of 16
in reply to: Phil.E
I design a Steel parts over 100 kg, density  is 7.8 kg / m^3, how to change density    0.0078 g / mm^3 to 7.8 kg/ m^3?
Message 9 of 16
Your calculation is exactly the same, just divide your answer by 1,000,000.
Brett.
Message 10 of 16
Brett.
Thank you your help. But this not my want, we need to know some casting parts over 1000 kg, the density g/mm^3 can't fit our request.
Brett.
Message 11 of 16
Sorry, I think I may have misunderstood your question.
What are you trying to do?
Brett.
Message 12 of 16
Try this.
1m^3 = 1,000,000,000mm^3
The specific gravity of steel = 7.85
The formula for a piece of steel in kilograms is - ((volume in mm^3) x 7.85) / 1,000,000)
The mass of a cubic meter of steel  is 7,850kg     -     I.E. 7850kg/m^3
The formula for a piece of steel in grams is - ((volume in mm^3) x 7.85) / 1,000)
The mass of a cubic millimetre of steel is 0.00785g     -      I.E. 0.00785g/mm^3
To get the weight of any other material - substitute the specific gravity of that material for the number 7.85 in the calculations above.
Does this solve your problem?
Brett
Message 13 of 16
Thank you for your reply.
thank you.
@Anonymous wrote:
Try this.
Brett
Message 14 of 16
robduarte
I posted this video on the topic recently: https://www.youtube.com/watch?v=TikstpkcRuI
Rob Duarte
Associate Professor in Art, Florida State University
Co-Director FSU Facility for Arts Research
http://art.fsu.edu/rob-duarte/
Twitter | YouTube
Message 15 of 16
in reply to: robduarte
How check the density/mass of the part in the mobile app. Is it possible  I haven't found any info about this or is the mobil app only a viewer program that can't measure mass?
Message 16 of 16
g-andresen
Hi Mattias,
try it this way:
regards
günther
