I can't even figure out something as basic as select/copy/paste - there are bits of the sketch that I think should be copied that aren't.
What am I missing?
https://screencast.autodesk.com/main/details/c5e672ce-d33a-40c8-bb26-c8b315615810
Rishi Vadher
Personal Page
Facebook | Twitter | LinkedIn
Rishi Vadher
Personal Page
Rishi Vadher
Personal Page
Hi just made it
https://screencast.autodesk.com/Main/Details/81f8e2d5-f0c0-4685-af73-fefeb44cbda0
it workd fine with me have put the file
best
Rishi Vadher
Personal Page
Hi James,
I've got a feeling this could be related to the 'Select Through' setting. In the Select > Selection Filters menu, is Select Through enabled or disabled?
If disabled, try enabling this option and doing the copy & paste (or patterning) again.
When this option is unchecked, only 'foreground' objects will be selected when doing group selections. It's possible that the sketch lines are being determined as 'behind' the sketch points, which could be causing the behaviour you are seeing.
Let me know whether that works or not.
Many thanks for posting this one!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
Hi Jake, I just tried to enable "Select Through" on a Mac using Parametric Mode. It did not work. I could not even copy a sketch by selecting the whole sketch using the left or right selection technique. Only by changing to DM mode the sketch could be copied using the copy method and moved successfully. At Parametric Mode the usual CMD C or V could not do anything but these commands worked at the DM Mode on MAC. Maybe Control C and V work on PC, but not MAC. So DM Mode is needed to copy or move sketches.
Hi Kingson,
You're right, whole sketches can only be copied & pasted inside Direct designs at the moment. But inside any design (Parametric or Direct), you should be able to copy & paste parts of a sketch while you are editing the sketch (i.e. before hitting 'Stop Sketch'). This is what I thought could be helped with toggling Select Through. If this doesn't work, that's something we'd definitely want to look at.
Thanks!
Jake
Jake Fowler
Fusion 360
Hi Jake, you are also correct. At the Parametric Mode, within the same skeching environment the users can copy and paste sketches, as well as selecting sketches and moving them.
You are also correct, it is the "Select through" that has to be enabled. Thanks for the tip! Now I will make sure that the "Select Through" box is checked all the time!
I think this solved James' sketching problem!
Thanks!
Thanks - checking the "Select through" box meant that I got behavior that made sense, and it looks like I can copy now.
