Going back and forth with model in Inventor / Fusion
2 REPLIES 2
ClarkFalcione8861
186 Views, 2 Replies
Why do I lose dimension relationship when I save my model back to inventor? It doesn't seem right that I have to re-demsion everything!! Is there a way to import my .idw drawings AND .ipt parts to Fusion so I can do this???
2 REPLIES 2
Reading your other posts - I don't understand why you are leaving the Inventor environment to edit models in Fusion 360?
I recommend that you post an Inventor model in the Inventor forum and explain the edit that you need to make so that someone can demonstrate how to edit your model in Inventor so that you do not lose associativity to the drawing.
