Fusion crashes and completely dissappears while copying from...
1 REPLY 1
Helmi74
193 Views, 1 Reply
another ugly bug: Fusion crashes repeatedly after copying one component from one open design (via context menu copy) to another (context menu paste new). It beachballs for 10 seconds and then completely disappears without even bringing the Crash Reporting up.
The component has some subcomponents and also includes a small mesh - both the mesh and the component itself aren't really big.
Frank / @helmi
Established 1974. Internet addicted since 1994. Collector of Kudos.
Tags (3)
1 REPLY 1
Thanks for posting about this problem.
Unfortunately we were not able to reproduce the problem here, is it possible to attach your model to the forum? You can save the file as an f3d file using the Export Archive tool in the application menu.
If you would rather not post the model here, we can arrange another way to transfer the file.
You also can email me if you like.
cathy.wang (at) autodesk.com
Cathy Wang
Software Engineer
Fusion 360 Team
