Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Fusion 360 install problem
43 REPLIES 43
Message 1 of 44
3710 Views, 43 Replies
When I try to install Fusion 360 from the link in the activation email (subject: Your Fusion 260 Account is Ready!), I get a dialog with
Unexpected Error
HTTP Error 403: Forbidden.
Please attach the file ".\streamer.log" to any problem reports before closing this dialog.
A search of my computer fails to find streamer.log.
I'd appreciate some help with this.
Thanks.
43 REPLIES 43
Message 21 of 44
in reply to: jessica.t
Hi I've got the same problem here
I got message "Please attach the fle "\autodesk.wedeploy.streamer.log" to any problem reports before closing this dialog' when I tried to install it
Please kindly send the refreshed link for me
I'm using Win 7 x64
Message 22 of 44
innovatenate
@Anonymous
Can you  upload the autodesk.webdeploy.streamer.log located in %LOCALAPPDATA%\Autodesk on your machine to this forum thread? You may also e-mail it me directly at Nathan.Chandler@Autodesk.com.
Nathan Chandler
Principal Specialist
Message 23 of 44
I try to install fusion 360 on my pc (mac book air osx 10.10.1) but i get a diaolog with:
Unexpected Error
Message 24 of 44
innovatenate
Can you check the below directories for the autodesk.webdeploy.streamer.log file?
On Windows:
On Mac OS:
~/Library/Application Support/Autodesk/
This is the installation log file for Fusion 360, it may reveal further information about the problem. Please attach it to a reply.
You may also want to review the below link for tips on how to troubleshoot network connectivity for Fusion 360. From the error message, I would assume that you have a firewall or proxy server that may be interfering with the streaming installer file’s internet access. However, it could be one of the other factors mentioned in the below link.
http://knowledge.autodesk.com/support/fusion-360/troubleshooting/caas/sfdcarticles/sfdcarticles/Netw...
Please review that link and let me know if it helps to resolve this issue.
Nathan Chandler
Message 25 of 44
Turius94
in reply to: innovatenate
I also am experiencing an issue when installing Fusion 360.
The error is "unexpected error" the message "Please attach ....../streamer.log"
Thank you in advance for your help
Message 26 of 44
kpbprod58
in reply to: Turius94
Can you attach the log file specified in the error message?
Message 27 of 44
Turius94
in reply to: kpbprod58
Thank you for your interest. I hereby attach the file
Message 28 of 44
baribak
In looking at the log file we are seeing an Errno 10109 which appears if there's a network connection issue. So we'll start there.
Can you tell us a little more about your network setup?
  1. Are you on a cabled or wifi connection? Is the speed adequate? www.speedtest.net can help you see what your upload/download/ping speeds are. Our presumption is this is not the problem but always good to check.
  2. Presuming you already have an A360 userid/account can you access your hub via the web browser - myhub.autodesk360.com? We'd want to know if you're blocked or not.
  3. Are you working in an environment that uses a proxy server? If so, do you know if it's a non-authenticating or authenticating proxy setup? Fusion works with most non-authenticating proxy setups without additional configuration needed. For autheticating proxy setups you'll likely need to add the Fusion servers to your "safe server" list. To see if this might be the case aside from asking the IT folks you can try installing from another network (e.g. Starbucks or a public libary).
  4. Do you have an antivirus program or a firewall running? Depending on the settings Fusion can be blocked from connecting to the network. If this might be the case you can try disabling these, run the install, and see if there's any difference.
  5. Could there be an environment variable or redirect blocking us? Specifically anything that might be redirecting network traffic through a specific server e.g. a Hosts file entry or the HTTP_PROXY environment variable. The Hosts file is located in \Windows\System32\drivers\etc. You can check the environment variables either by opening a command window and typing "set" then <Enter> or thru Control Panel > System and Security > System > Advanced System Settings > Environment Variables button.
Hope this helps with debugging. We look forward to resolving this issue and getting you up and running with Fusion 360!
Kevin Baribault
Fusion 360 Quality Assurance
Message 29 of 44
Turius94
in reply to: baribak
1. I am on wifi, I am connected to the same network with another PC and Fusion works fine on it. The speed is decent (10mb/s)
2. I can access
3.I am not using a proxy.
4.I am not using firewalls or antiviruses.
5 There is no variable redirecting me.
Could Windows 10 be the problem?
Livio
Message 30 of 44
baribak
Windows 10 could be contributing but we have run tests and Fusion doesn't have any apparent issues running on it outside graphics support.
Can you send me a good day/time/number you can be reached so we can more quickly troubleshoot/resolve?
Send it to kevin dot baribault at autodesk dot com.
Thanks!
Kevin Baribault
Message 31 of 44
iSuat
Unexpected Error?
Message 32 of 44
baribak
in reply to: iSuat
From the log there seems to be some communication issues with the network. Can you tell us more about how you're connecting to the internet? e.g. wifi, cabled, cable modem, wireless router, etc. Can you also go to www.speedtest.net and check the speeds for upload/downloads?
Finally, do you have other Autodesk products installed? If so, which ones?
Thanks!
Kevin Baribault
Message 33 of 44
iSuat
I download Fusion 360 from Mac App Store without problems. I think this is same app, is it?
Message 34 of 44
baribak
in reply to: iSuat
Yes it is the same application.
Kevin Baribault
Message 35 of 44
mhattaaa
can you send direct link to download fusion 360? i have error too when installing fusion 360
Message 36 of 44
baribak
in reply to: mhattaaa
You should be able to access the download at: http://www.autodesk.com/products/fusion-360/try-buy
However if you're experiencing issues with the installer I am not sure this link will make a difference. If you continue to experience issues with the download and install please send us the autodesk.webdeploy.streamer.log file which is located at:
Windows
  c:\users\username\appdata\local\autodesk
Mac
  /users/username/library/application support/logs
This might help us determine what may be causing the issue.
Hope this helps.
Kevin Baribault
Message 37 of 44
Ale-Yael
Hi all there!
Same problem here, I can't install fusion-360 in OS X 10.9.5. Connected via Lan.
thxs
Message 38 of 44
wens3
Hi Kevin, I cannot install fusion 360. I am using Mac and just get an error message saying it cannot install. Please can you help me.
Thank you.
Message 39 of 44
baribak
in reply to: wens3
Sorry to hear of your troubles.
Are you running the installer via the Fusion 360 Client Downloader? Or are you installing from the Mac AppStore?
Also, what are you seeing when you try to install? Does it start then stop? Never starts?
And what kind of network are you running on? Office? Home? Public?
Has Fusion ever run on this system?
Finally, there should be a log file created under /users/username/library/logs called autodesk.webdeploy.streamer.log. If you find it can you attach it here?
Kevin Baribault
Message 40 of 44
I am having this same issue. Could you mind send me the link via email? 1121117652@student.mmu.edu.my
Please and thanks.
