Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Fusion 360 extremely long to startup and only works in offline mode
2 REPLIES 2
sparkbuzz
725 Views, 2 Replies
I'm using Autodesk Fusion 360 v2.0.1193, and since tonight, Fusion takes around 5-8 minutes to start up. When it eventually does, it only runs in offline mode?
I've tried restarting the application, restarted my Mac? Any ideas what could be wrong?
2 REPLIES 2
sparkbuzz
in reply to: sparkbuzz
I think I need to reinstall, but worried I will lose a lot of changes to my design. I've been working in offline mode yesterday, so did a lot of changes to my model which I assume will be lost if I do a clean install.
I'm trying to recover with time machine on Mac, specifically the ~/Library.../Application Support folder which seems to work, but I lose my changes.
Where are the offline models saved so I can try to exclude that from my time machine restore?
innovatenate
While in offline mode, you may use the export archive command to create a *F3D file that is stored on your local hard drive:
1. Open Fusion 360 (Offline Mode is okay)
2. Open the design
3. In the main menu, select Export Archive
4. Save the *.F3D file on your local hard drive.
5. Back-up the archive file to a safe location
For the connectivity issue, is there anything different on your network that would prevent Fusion 360 from accessing the web (e.g. a new router, updated security software/anti-virus)? Are you currently able to access the internet on that machine?
Nathan Chandler
Principal Specialist
