cannot create or edit files.
I have uninstalled and reinstalled
here is the message and text:
LiveUpdate Error
Traceback (most recent call last):
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\registry.py", line 135, in _database_init_and_migrate
sqlite3.OperationalError: database is locked
During handling of the above exception, another exception occurred:
File "<string>", line 1, in <module>
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/neutronSupport.py", line 162, in validate_application_path
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/update.py", line 392, in has_registry
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/update.py", line 108, in registry
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\factory.py", line 329, in install_registry_root
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\factory.py", line 326, in _new_reg_root_helper
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\registry.py", line 345, in __init__
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\registry.py", line 124, in __init__
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\registry.py", line 147, in _database_init_and_migrate
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/adsk\dls\streamer\registry.py", line 197, in _runscript
LiveUpdate Error
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/neutronSupport.py", line 182, in app_update_required
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/update.py", line 252, in app_update_required
LiveUpdate Error
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/neutronSupport.py", line 202, in uninstall_required
File "W:/SRC/Lib64/Release_Build/Neutron/Server/Base/pylibtemp/update.py", line 360, in uninstall_required
The servers were down for maintenance. You should have access to your data now.
Andy
