I have problems Mirroring a pattern selection.
In Detail: I did "pattern on path" to a component. Then tried to mirror some steps later the components, but the mirror appears somwhere in the middle of nowhere but not mirrored on the other side of th object.
This is arbitrarily repeatable with allways the same effect.
Thanks for posting this northsight, this is an unusually behavior. We're looking into it now - I've sent your post to our QA/dev team. I'll keep you posted on what the outcome is. Thanks again!
Thanks for posting this issue. I'd like to know more about it.
Would it be possible to get a copy of the data in this condition? If you don't want to post it here you can email it to me.
phil dot eichhmiller at autodesk dot com
