Is anyone able to delete files from Fusion360?
Files uploaded to Fusion can not be deleted.
Tried to upload a video but it was in wmv format so attached a png.
Solved by RajkumarIlanchelian. Go to Solution.
Thanks for reporting this. I was able to reproduce this issue. The delete does not seem to work from the Activity feed but the delete works from the data folder. We will take a look as to why the issue is in the activity feed.
Rajkumar Ilanchelian
Autodesk Fusion
Join Fusion Insider
