In the timeline edit the Extrude feature.
Previews OK, but I get an error on selecting OK.
Thanks for posting this! Looks like you've found a bug here. I'll forward this to the development team & we'll get this one fixed - apologies for the inconvenience.
For now, a quick workaround might be to change the Extent option to Distance, and use a value that extrudes through the entire part (rather than specifically using the All option). This seemed to work OK for me. If this doesn't help you, let us know.
Thanks!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
@jakefowler wrote:This seemed to work OK for me. If this doesn't help you, let us know.
Thanks!
Jake
This work-around worked once for me - but I could not get it to work consistently.
As I experiemented with several different settings for the Extrude-Cut, it would no longer work at all.
I deleted the feature and tried to reproduce with a given distance - and it didn't work.
I deleted the feature and the sketch.
Recreated the sketch and cannot select it for Press/Pull.
(see attached image)
Which brings up a couple of other problems -
1. Is there a way to directly attach a *.f3d file here? (what I am doing now is saving an Archive locally and then attaching it here)
2. When I try to attach a *.f3d file using IE 11 I get the error screen shown below, yet I am able to attach using Chrome.
Thus far the entire experience, with Fusion and communication here in the community feels like a Beta experience.
With more experimentation - it appears that Fusion gets confused if there is both open (the Projected Cut Edges not converted to Construction) and closed profiles in the sketch.
I decided to try to keep the problem as simple as possible.
Extrusion doesn't work correclty?
For some reason I cannot select Sketch2 for a Press/Pull.
Any ideas what I might be doing incorrectly?
What sketch shows in the browser? (Sketch3)
Two sketches are shown in the timeline.
I created Sketch2, and trouble and rewind the timeline before Sketch2 to create Sketch3.
Try to Extrude-Cut Sketch3.
Drag the last sketch in the timeline to occur before the previous sketch.
How does the browser change?
I am getting unexpected Extrude-Cut relults on simple primitive geometry (sphere) as well.
Sorry to see that you’re still having problems, and many thanks for taking the time to log all of these.
Just to make sure I’m capturing everything you’ve seen:
Again, appreciate you continuing to update this thread, and sorry for the problems you’re encountering. Once we nail down these issues, we can get them logged with the development team, and get them resolved as soon as possible.
Many thanks!
Jake
Jake Fowler
Fusion 360
