driver not recognized
1 REPLY 1
trudyfreestyle
175 Views, 1 Reply
yesterday when trying to plot i received the following message;
this plotter configuration cannot be used for one of the foloowing reasons, the driver cannot be found, the device cannot be found or the driver has a problem. The none plot device has been subsituted.
I can print and make pdf;s no problem in other programs.
Thanks!
1 REPLY 1
Thank you for posting. What commands are you using in Fusion 360, Capture Image?
I see a Print in the Item Details page, is this the command you are using (See below image)?
Which PDF Printer are you using? Have you tested any others?
Nathan Chandler
Principal Specialist
