Using a 2013 Mac Pro 12 Core, 28 GB 1333 MHz Ram, Geforce GTX670 VRAM 2048 MB. Should this be an advantage for modeling in Fusion 360? Seems to me Fusion 360 grinds it to its knees. It barely moves.
Solved by jakefowler. Go to Solution.
The computer looks good, so I have to assume that it might be data set specific.
Can you describe what you are working on?
Cool Project!
Do you know if the there are many star points in the model? You may consider trying the Enable Better Performance feature from the Sculpt ribbon > Modify drop down menu.
You may learn more about this feature in the below video.
Please keep us updated on your progress.
Might it also be possible to provide some details the types of performance problems you are seeing? In particular:
This will help a lot in tracking down what the bottleneck might be.
Many thanks for reporting this!
Jake
Jake Fowler
Principal Experience Designer
Fusion 360
So this is disturbing, we agree.
cold you direct message me a screen shot of the model? I just don't have a feel for how complex the topology is. We know there is a slow down with very large tsplines bodies and I'd like to see how big yours is to see if it might fall into that case. Either way its not right but want to try and eliminate possible causes.
Also some other quick things to try.
Can you turn off all the effects lie anti-aliasing, shadows and such?
In the preferences can you look at graphics and turn selections to simplified.
Do any of these changes help?
Also, regarding a few of the things you mentioned:
Really appreciate the additional details, we'll try to get to the bottom of these issues.
Many thanks indeed,
Jake
Jake Fowler
Fusion 360
Hi Edd,
That's great, glad to hear that helped!
We'll still take a look into this issue, to see if there's anything to improve the interactivity at close zooms: we'd obviously prefer to avoid any jerky behaviour if we can.
Please do let us know if you continue to encounter any problems.
Many thanks!
Jake
Jake Fowler
Fusion 360
