Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Coloring a solid body face
2 REPLIES 2
4269 Views, 2 Replies
I'm able to use the color picker tab (available from the 'Materials' command) to change the color of a solid- is it possible to change the color of a single face on that solid? Selecting the face and using the picker results in no visible change.
Tags (1)
2 REPLIES 2
innovatenate
With the geometry to modify highlighted/selected and the Material Browser open. Try right clicking on the desired material in the Material Browser (visual tab) and choose 'Assign to Selection'.
Check out this video for further detail.
http://screencast.com/t/K5KLRquH
Hope that helps.
Nathan Chandler
Principal Specialist
in reply to: innovatenate
Thanks! I'm able to assign to individual faces now.
