Why can't sketch points be made coincident?
Which brings up another point (pun intended) is there a way to make midpoints of lines coincident without adding sketch points? (I already figured out a work around to making the two sketch points coincident)
Thank you to post the problem with detail information!
Glad to know you get a work around.
It's really not our expectation Fusion can't make the two middle points coincident. I transferred the issue to the developers and they will fix it in a near update.
Currently, we need add a sketch point to be midpoint of a line. I will transfer your requirement to PD. They will think about it in future.
