When I create a construction plane through an edge of a solid, the edge does not seem to be part of the plane. I can not lock to it or use the edge to constrain other elements in the plane.
Solved by TheCADWhisperer. Go to Solution.
While in Sketch are you using the Project Geometry tool?
No. I will try projecting the edge to the plane. Thanks (if it works). No, really, thanks.
