Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Change Axis?
3 REPLIES 3
mxstylie
595 Views, 3 Replies
Change Axis?
Is there any way to change the axis orientation in my modeling environment. I can't for the life of make Z vertical on any part no matter which plane I create the part from. Thank you
3 REPLIES 3
schneik-adsk
in reply to: mxstylie
Check out the application options and there is a setting to set Z up.
Kevin Schneider
mxstylie
in reply to: schneik-adsk
Thank you so much... where can the application options be found?
mxstylie
Found it! thanks!
