Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Cannot delete files
12 REPLIES 12
Message 1 of 13
cekuhnen
1263 Views, 12 Replies
Cannot delete files
I have many files where Fusion crashed and after restarting it rendered the files impossible to delete because they are supposetly to be in use ?!
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
12 REPLIES 12
Message 2 of 13
philip.s
in reply to: cekuhnen
Our apologies for the inconvenience Claas.
This is actually an issue that we are aware of and are in the process of investigating / building out a fix. For the mean time as a workaround, are you able to promote one of the older versions and then delete as needed?
Message 3 of 13
cekuhnen
in reply to: philip.s
Oh no problem - good to know that it is not my side.
How can I actually go back a version?
Claas
Claas Kuhnen
Message 4 of 13
philip.s
It's pretty simple. To promote a previous version, open the design details (as opposed to editing it), click on versions, and then the promote icon PROMOTE.PNG.
Message 5 of 13
cekuhnen
Duh the versioning area sure - the term promote throw me off.
Also after doing this I still cannot delete the file(s).
Claas Kuhnen
Message 6 of 13
philip.s
Shucks!
Are you able to invite me (philip.schmelzer@autodesk.com) to your group so that I can take a look?
Message 7 of 13
cekuhnen
I will do that.
Claas Kuhnen
Message 8 of 13
philip.s
Hi Claas,
Following up on this one, we have identified the inability to delete a design as a defect and are investigating potential fixes. As a workaround, and in order to remove the "item is currently in use" message, can you please try opening and closing the design and then deleting?
Message 9 of 13
kingson138
Hi Philip, Thanks for the tips on promoting files. I did have the same problem and now I was able to promote one of the previous versions, opened it and selected "close all". My  "undeletable files" finally deleted. Your tips on promoting previous versions are also very useful when a previous design version is more favorable then the latest version. I was able to promote and select the previous version. It saved me the trouble of recreating it. Thanks!
Kingson
Using Apple computers
Message 10 of 13
cekuhnen
What I found out was that opening the file adding geometry like a simple solid cube closing the file enabled me to delete it then. This way I removed 2 of my wheel files today. I leave one for you to test with.
Claas Kuhnen
Message 11 of 13
AndrewSears
Thanks for the input Claas.  This is not normal behavior and we are looking into it.
I will get the remaining wheel.f3d file from your group to use for our research.
Cheers,
Andy
Message 12 of 13
cekuhnen
in reply to: AndrewSears
Sure feel free to do so. I can keep in my account if needed.
Claas
Claas Kuhnen
Message 13 of 13
I also encountered this problem. Opeing a sketch on the surface of the part. saving change and closing, then deleting allowed me to get rid of the problem file. Also not that trying to do CAM on the part that had become undeleteable chewed up massive amounts of RAM and there was noticeable slowdown, which eventually led to a crash of the program entirely.
