Hello!
I hadn't used fusion 360 for about 2 months, and when I first opened it again today I had to download and install the update.
After doing that, I tried to edit files but the Fusion UI would never pop up. Then I tried creating one to test what was going on,
and I'm unable to do it aswell, the only clue I have is this message you can see in the image at the bottom.
OS is Windows 7 64-bit
I also tried a clean install following the instructions given on the forum on cache clearing.
Thanks in advance for any help you guys can provide.
Sorry that you're having this issue. Would you please share your account name with us so we can take a further look. Email me at: LiangDOTLiu@autodesk@com or give a private message please.
Macro Liu
Fusion QA Team
Andres,
Could your previous version been a beta version?
This thread will guide you through how to uninstall the beta version.http://forums.autodesk.com/t5/Get-Help-with-Fusion-360/How-to-uninstall-beta-and-export-designs-whil...
If you think that you previous version might have been beta, I would suggest that you try this then re-download.
Please send us an update when you have an opportunity.
Thank you.
I have the same problem as Andres is describing. I get the same error message "Xdio subtype(design/simulation) is either empty or null".
Additionally, when starting the Fusion 360 application I get another error message "PLM 360 operation failed : 500".
I am running Fusion 360 version 1.8.674 on OS X 10.8.5. I have tried uninstalling Fusion 360 and then reinstalling it, but the same problem remains.
Please advise on how to resolve this.
Many thanks in advance!
andres.bofill and ilarsson,
I confirmed the correct information on the back end of this request.
Can you both try this again and let me know of your results.
Thank you.
It's working now!
The difference I saw, was that a few seconds after loging in,
some indicators on 'how to create and import files' and a confirmation button pop up.
After that "Design / Import" tabs appear once again and I can flawlessly access the application.
Was that stage missing somehow?
Once again thanks for all the help!
Thanks for getting back on this quickly!
There are some things that work and some things that were revealed after you made the correction.
What worked:
– The Hub now shows the Import tab, and it is possible to create a new design. There is no error "Xdio ..." as before.
What was revealed in the process:
– An error stating: "Unknown exception when uploading file Hand shaped cup.6f46df38-8e80-4d33-9935-c419d65f3083.f3d to your Autodesk 360 account. Please ensure network connectivity."
"Hand shaped cup" was a design I made the other day, and after getting the "Xdio ..." error, this design was not possible to open or edit. The preview was showing in the list, but clicking on it caused Fusion 360 to hang.
– An error stating "PLM 360 operation failed : 404"
So I did some more testing, guessing that somehow the application on my computer and the backend got out of sync due to the (resolved) "Xdio ..." issue. Here is what I did:
Altogether I am happy I didn't lose the cup design I made, on the other hand if the test design I made was a "real" design it would have been less than great if it was just overwritten like the scenario above.
Please look into that and again thanks for resolving the other issue so quickly.
Can you please tell me the exact error message that you are receiving.
Thank you.
We think we found and resolved an issue with your Fusion account.
Please try it again and let us know.
Thank you.
I, too am having the:
Xdio subType(design/simulation) is either empty or null
Error when I try to create files (and can't edit preexisting ones, either).
Thanks for any help.
I'm unable to open existing designs in my account or create new designs.
The button or option to open an existing design does not seem to exist.
When I try to create a new design I get the following error: "Xdio subType(design/simulation) is either empty or null"
I'm running OSX 10.8.5, Fusion360 v.1.8.679
I've tried uninstalling and reinstalling using the instructions in the forums with no luck.
The servers were down for maintenance. You should have access to your data now.
Andy
